Sign in to follow this
Griffgriff
C20Xe Into 2B
Hi all
I've Decided to go for the c20xe option into the 2b, also been offered a '92 Sierra 1.8lx manual. Would it be worth buying the whole car rather than sourcing a gearbox? What bits are needed from a Sierra to get the xe into my hood 2b I already have a Sierra rear diff and prop. Thanks in advance for any help
Share this post
Link to post
Message Ickle on here he done the conversion not that long ago
Share this post
Link to post
Just fitted Steve in Stockports old c20xe, i used the zx6r bike carbs and a megajolt, (had the cam pulley machined to be a 36-1 trigger wheel) you will need a bell housing to mate with the type 9, (consider other gearboxs that will fit straight on) otherwise well happy with mine Nice power level in the 2B easily controllable but has grunt!
if you need any help drop me a pm, literally just fitted this in my 2B.
Alan.
Share this post
Link to post
Got a C20XE in my series 7 and very happy with it. Runs on a couple of 45 webers and a non ecu setup but pokey enough and dead simple too. A very torquey set up. Good luck with your installation, there are plenty of knowledgeable people on this forum who will be able to guide you should you need it.
Share this post
Link to post
  • Similar Content
    • By Nicholas Matthews
      Hi all. My names nick and I'm new here, I wonder if anyone would be able to help me. I'm after c20xe/let standalone management to run my turbo in my Robin Hood. Is there anyone out there that has one for sale at all. Ideally the xe standalone management.
      Many thanks for taking the time to read nick.
    • By MarkBzero
      Thinking of upgrading rear brakes on Zero, currently have 2l Sierra drums. They generally only just pass MOT and I have fitted new shoes and adjusted them.
      What do I to do the conversion to discs? I see kitspares to the brackets and there is some questions about fitting to the rear of the disc or front of the car.
      Any help appreciated.
    • By deebee 55
      Hi i have a rover 2.0 t series super spec which starts and runs on tick over but give it the slightest bit of throttle and it cuts out ,.
      ive been in-touch with with Alan richey who has made a study of the ecu and he told me it sounded like the TPS , i checked this out and he seems to have put his finger on the problem because with or without it plugged up its just the same i need to discover if its the wiring or the sensor does anyone know how to test the sensor before i go shelling out my had earnt , thanks
      Dave
    • By matvic
      After months of not being able to start the engine, despite fuel, spark, air and timing all OK (Pinto 2.0 with DGAV Webers), it started yesterday by holding a rag over the air intake to the carb. Battery has died due to the number of times I have tried to start the car. Today with a new battery, same thing. Car won't start, but as soon as I put a rag over the air intake it started fine. Once it has been running for a few in minutes it then starts fine every time, while it is hot.
      Any ideas why or what to do?
    • By christcp2
      I have a pinto engine with twin webers. It runs quite well under light acceleration but after heavy acceleration the engine and exhaust start to feel like they are being choked. This get steadily worse until the engine loses all power and needs to be left for an hour to recover. Could anyone suggest what might be causing this please? Would air leaks in th exhaust cause this?
