matvic
Engine Won't Start
After months of not being able to start the engine, despite fuel, spark, air and timing all OK (Pinto 2.0 with DGAV Webers), it started yesterday by holding a rag over the air intake to the carb. Battery has died due to the number of times I have tried to start the car. Today with a new battery, same thing. Car won't start, but as soon as I put a rag over the air intake it started fine. Once it has been running for a few in minutes it then starts fine every time, while it is hot.
Any ideas why or what to do?
Share this post
Link to post
I took the choke completely off as never used it
I usually pump the pedal 6-10 times before starting and then it starts straight up.
Manual or electric pump?
Share this post
Link to post
does it have a choke??
It has an automatic choke and the butterflies are closed when cold and open when hot, seems to function ok.
Share this post
Link to post
Manual pump, but I still couldn't start it with lots of pumping/no pumping/spraying cold start/spraying petrol directly in etc
Share this post
Link to post
Strange, if you left it a while in case of flooding, sprayed cold start in,it still wont start or even attempt to?
Share this post
Link to post
Yep, have tried leaving it, cleaning the plugs, it doesn't even pop or splutter.
Share this post
Link to post
You defo have a strong spark?
Nothing to compare with, it's a yellow/white spark, should it be bluer?
Share this post
Link to post
There is possibly a ballast resistor in the +ive lead to the coil, (check Haynes) what this does is allows 12v for starting, but as soon as it fires, it drops to 9v to the coil, these are notorious for going duff, and will give you the weak yellow spark making it hard to start.
Also remove the air filter, if you see fuel being squirted into the manifold when the accelerator is pressed, then that confirms that it's not fuel related
Share this post
Link to post
Thanks for this, I have tested and it drops to 9v whilst still trying to start. I thought I had an non-ballast system and can't see a ballast resistor. I think I have put a non-ballast coil in. There is something on the wire to the +ve of the coil, but I was told it was a capacitor to smooth the signal to reduce any interference for radios etc. Currently I have removed this and wired directly to the coil. There are two wires going to the +ve of the coil...implying ballast?
Have just tested again, with the ignition on the +ve is 12v. When trying to start it drops to 9v. This seems to be the wrong way round?
Fuel is fine, I can see it going in,
Edited by matvic
Share this post
Link to post
The later ballast resistors didn't look like a component, just a thick part of wire.
Try running a 12v wire to the coil and see if that makes any difference. depending on the year of the donor ignition, and which wiring harness you have in, one of the 2 wires could go to the tacho (In the Haynes manual, and ford colours, it's the green one)
What ignition system are you using? points? Ford electronic dizzy? type of ignition ECU? what year is the car based on?
Edited by Big Jim
Share this post
Link to post
OK, recharged the battery overnight and ran a 12v to the +ve coil and it dropped about 4v during (15v - 11v), but wouldn't start, I then used the rag method to start it, and the coil is at 9v at 3000rpm. I am now thinking I need a ballast coil. I checked the resistance of the new coil, about 5 ohms. The old coil I took off is 1.6 ohms. Again does this indicate a ballast coil? What is the effect of having a non ballast coil if I should have a ballast one?
The two wires from the +ve coil are green and green with a black stripe.
Ignition is a Bosch ford electronic dizzy from a Sierra, but the engine is a RS2000 (1973)
Thanks for your help, I am learning loads :)
Edited by matvic
Share this post
Link to post
Put the old coil on and am getting different voltages!
New Coil (5.6ohms) = 12v ignition on, 9v whilst starting, 6v at tickover, 9v at 3000rpm
Old coil (1.6ohms) = 12v ignition on, 10v whilst starting, 12v at tickover, 12v at 3000rpm.
Neither will start it from cold, but both will start it hot.
Looked at Haynes and the two leads are for 1.3 and 1.6, I had a 1.6, changed the engine, but nothing else. However, it has worked fine for the last two years.
Share this post
Link to post
  • Similar Content
    • By deebee 55
      Hi i have a rover 2.0 t series super spec which starts and runs on tick over but give it the slightest bit of throttle and it cuts out ,.
      ive been in-touch with with Alan richey who has made a study of the ecu and he told me it sounded like the TPS , i checked this out and he seems to have put his finger on the problem because with or without it plugged up its just the same i need to discover if its the wiring or the sensor does anyone know how to test the sensor before i go shelling out my had earnt , thanks
      Dave
    • By christcp2
      I have a pinto engine with twin webers. It runs quite well under light acceleration but after heavy acceleration the engine and exhaust start to feel like they are being choked. This get steadily worse until the engine loses all power and needs to be left for an hour to recover. Could anyone suggest what might be causing this please? Would air leaks in th exhaust cause this?
    • By Griffgriff
      Hi, could anyone help me with info on the best place to get engine mounts for a Zetec black top in a good 2b? I've seen some on eBay for £50 odd, are these any good, are they a good fit? Or are they universal? Thanks in advance for any help
    • By Griffgriff
      Hi all
      I've Decided to go for the c20xe option into the 2b, also been offered a '92 Sierra 1.8lx manual. Would it be worth buying the whole car rather than sourcing a gearbox? What bits are needed from a Sierra to get the xe into my hood 2b I already have a Sierra rear diff and prop. Thanks in advance for any help
    • By Griffgriff
      Hi I've recently purchased a 2b,
      Asking for info on the best/easiest engine instal option? The car currently has rear diff and prop to run a 2 litre pinto set up, the engine and gearbox is no longer with the car. My rough thoughts are leaning towards either the 2.0 Zetec or the st170 engine, or possible a vauxhall red top?I know I'm asking for a lot of info but could anyone advise me of options and parts I'll need ie any conversion kits available to get the Zetec in the 2b?, gearbox options? Can I run the standard injection and ecu? Or do I have to switch to bike carbs/throttle bodies, thanks in advance for any info!
