Prop Shaft
tractor
Oh right, I'm with you, sorry. Hold on, I have an old prop which will have a degree of marking on it....
(runs off to garage....)
edit: both my props show 7cm of distinctly cleaner looking shaft tip (ooer), so I think it's safe to say the rear seal was sitting at that point on the prop. Obviously there's quite a bit of movement there, you could have pushed the shaft further in or pulled it out some more and it would still have been engaged on the output shaft either way, so there's a degree of 'play' to be had...
You can get these things :-
http://www.ebay.co.u...=item1c3903f5c7
http://www.rallydesi...oducts_id=13487
I used one on the Exmo with the Rover conversion, more out of necessity than choice really. They are pretty cheap nasty things, you lose that lovely 'snickness' of a type 9 and I had to file mine quite a bit to get 1st to select properly without interfering with reverse... but they do work. Much as I grumble, it's far better than having a gearstick tucked away under the dashboard (which is rather undriveable).
