Spark Plugs
Liberal Plus gas /WD40 soak , good fitting socket held square to line of plug and a quick firm 'snap ' ,once its moving 1 turn out 1 turn back in 2 out 2in till it moves free, job done , patience and perciverance[ pat and percy you 2 best freinds mowerman
The taper fit plugs in Pintos are renowned for being hard to remove , expect to snap them if they have been in that long.
Get a new set of NGK's and a liberal amount of copper grease on the threads when you fit the new ones and every time there after.
Patience, patience and patience.
Lots of WD40, hot air and a very big steel bar and lots of patience....
More WD40 and more waiting...
More WD40 and waiting..
Finally 4 plugs out and new ones in with a drop of grease.
We ave managed to remove the old ballast points ignition and put in new sparks, HT leads, ignition coil and change the distributor to a non point system, whilst tracking down an electrical fault and renewing part of the wiring loom. :sorry:
Crocodile smile fitted back on and a quick trip around the block to make sure it's running ok.......! 8)
Now the temperature sensor for the fan has packed up :diablo: ........I will just bypass it with a switch for now (done). :angel:
Just needs a good tune up and new temperature sensor and it should be ready for Hollowell :)
Thank to up the help today....Dino & Nikki.
The wife drinks..... A mixture of half & half pint of chilled Vodka, with crushed ice, topped up with lemonade and a slice of lemon, straw and no umbrella. :rofl:
Just 1/2's then? mowerman
