Windscreen Mounting Brackets
Stewart
Bench Vice , 2 inch round piece of wood, 12" adjustable spanner
No hammering, just gently bend the bracket into shape by holding in the vice and bending around the wood with lots of trial fitting. In short lots of small movements and lots of checking - just like you're making a Wallace and Gromit film....
To put the twist in I clamped the upright in the vice horizontally and used a 12" adjustable spanner to twist the lower section - again many small twists and check often.
Ian
Guest red-col
two pieces of timber on the floor with a gap between them to sit the section to be curved, then run over it slowly with the tyre part of a tintop car, nice and slowly stop when curved enough worked for me!
