Wheel Shake.
blue
Wheels would not balance correctly with untrue wheels, or tyres.
If your calipers are the single piston push pull type, and the sliders are partially seized, it could be the pads running on untrue discs.
Ok think I've found it !!
The fronts are polly bushed and where the front lower arms go through what used to be the anti roll bar the steel inserts were slightly to long so the bushes never squashed in the arms and the arms could move back and forth about 2/3 mm .
A little adjustment with the cut off saw later and both bushes do up tight.
Have not tried it yet as rain stopped play- but think I've found the problem.
