Pinto Compression
dandan62
I have just done a compression test and cylinders 1,2,4 are all around 170. Number 4 is 190. Do I need to worry? Car is new to me so I don't have much history and don't think its ever had a rebuild and not much clue on the mileage. It's the 1.6 so lacks some uummph but seems to run ok. Not too worried about that for now as my son will be driving it soon!
+1 with above.
Also possible slightly higher on 1 cylinder because of slight dampness
If the tappets are done and it runs well without white or blue smoke just ignore it.
Thanks everyone. Yes valve clearances all done but still sounds a bit tappetty. Typo as it was number 3 at 190. Didn't do it with wide open throttle though. Sounds like not much to worry about as there's no smoke. Cheers all. Loving this club! Coming to Stoneliegh so see you there.
