32 Mm Pipe With 90 Degree
stevedohc2b
Hi Stephen,
I needed something similar, & used a regular 90% bend in rubber & extended it with 32mm
ally tubing.
These may help?
http://www.carbuildersolutions.com/uk/gates-extra-service-32mm-id-90deg-rubber-hose-bend
http://www.carbuildersolutions.com/uk/aluminium-tube
http://www.carbuildersolutions.com/uk/aluminium-bends
Can do 28 & 35mm copper -- 32 & 35mm ally but no bends. 28mm copper plus a swept 90* bend one end & 28mm straight connector on t'other would give 31mm O/D plus if solder fittings used they will have a swaged ring which will prevent the hose pulling off.
sounds ok do you have this ?
Bob the new 32 mm hose i have is thicker than old and a bit tight to bonnet so thinking of getting it away from exhaust in metal as much as pos
Problem solved it was the side vent touching the hose pushing side out so lifted hose up to curve off bonnet and it fits fine
just a cut of a cable tie.Steve the B&Q was a good call they even do a curved bracket kit.
Stephen
