Robin Hood Exmo
Guest teggyrobinhood
Hi there i was wondering on some help i have a robin hood exmo with the longer front wheel arches/wings i was wondering if it is possible to put the smaller arches over the front wheels thank you.
Thank you markbzero ill have a look at that i didnt know how the long wings/arches fitted to the body ill have a look into it thank you.
Unlike some orther robin hoods the exmo has no where to mount bought arch stays they have to be modifyed and mounted to the suspension upright i am going to do same at some point its easier to make them from scratch
Search on here for exmo arch show better
If you mount to the suspension uprights the arches don’t turn with the wheels.
The brackets can be adjusted to fit to the hubs and then the arches will turn with the wheels.
Normally brackets directly of the body, probably rusted and you will have holes left in the body. A fair few on the forum have done this hopefully you will some pictures soon.
What i meant rich people have mounted them like yourself to the hub what i meant was the suspension strut via a clamp of some description got the wrong termanology
I have built my Exmo with cycle wings. I followed the destructions on the build video. They do not turn with the wheels because they mount to the suspension outrigger at the top and to a bar from the engine bay at the bottom. I have converted the original VHS build tapes to a series of mpgs, I could put these on my BT Cloud for you if you want, the cycle wing construction is on these somewhere. I have seen quite a few EXMOs with cycle wings that turn with the wheels, however you have to be prepared to cut off the ends of the outriggers (and presumably do a bit of welding to strengthen the ends). This needed because otherwise the top of the cycle wing will bash against the end of the outrigger when the spring is compressed by a bump.
I have uploaded some snaps and vids to BT Cloud, to help.
The snaps show the cycle wings, and steering wheel mounts, taken when I was stripping down for a rebuild.
The vids are extracts from the tapes that were supplied with the kit, for steering and cycle wings.
Snaps at https://btcloud.bt.com/web/app/share/invite/tLDkYg0ddk
Vids at https://btcloud.bt.com/web/app/share/invite/UulSi0fjPD
Hope this helps.
