Pair Gaz Dampers and Springs
Pair of Gaz Dampers and Springs.
Dampers 300mm open length, 240mm closed length
Springs 175lb 8" length
Used so some surface rust on the dampers but nothing a quick wire brush and some paint or Waxoyl won't tidy up. The adjusters are all nice and free and work fine.
Not 100% sure what these will fit but the dampers look the same as what I've got on the front of my 2B although the spring poundage might be a bit low so you might want to do a bit of measuring before you decide if you want them.
£50 for the pair plus £10 postage or you can collect from Tamworth if you want.
Edited by richyb66
I'll have them please
