Removing the spare wheel part of the chassis
SD252
 Share
Hi, not sure if this is in the right place as I've only just started using this...
I have removed the spare wheel off the back of my 2b as it's no longer a legal requirement. If anyone else has done this what have you done with the part of the frame it sits on? Mine currently is just sticking out and it's a bit of an eye sore!
that's a good point however it's sticks out so far! I could weld the loop back on after cutting off at the bottom of the tub to have the added protection for the tank
On 4/30/2021 at 6:15 PM, Bob Tucker said:
DSCF9348.JPG.2cd9c51e0e1336d1fc956811b3ad4cad.JPGProbably not the look you're after -- Florin's hoop was cut of & fitted with a tow ball -- which in this pic is under the "picnic  basket"  (Which contains all Florin's needs -oil/water/spares.
 Share
