Reluctant sale of my stunning and highly individual Robin Hood 2B.
I'm the original owner/builder. It's all correctly tested and registered on an age related plate, and with 'Robin Hood 2B' on the V5. Currently has 12 months MOT, and just 5500 miles on the clock. Never raced or abused, and always garage stored. It's in immaculate condition throughout, and always draws a lot of attention and compliments. Meticulously detailed with many unique and custom features - There's really very little you could describe as "standard", and I think it's reasonable to describe it was one of the most unique and immaculately presented examples built.
The base kit-spec is a mild steel chassis with stainless panels, front wishbones, and wide rear arch kit. The donor was a 1986 Ford Sierra 2.0GL
Although it isn't used much, I've kept it taxed and MOT'd, and looked after and serviced accordingly. For example, over the past few years I've done work on the brakes, suspension, and a new exhaust. After 20 years of ownership though, life moves on and it seemed like right time for a new owner to enjoy it.
£6750 ono
FULL DETAILED SPEC as follows...
Chassis and Bodywork
  • Mild Steel chassis etch primed and finished in 2K gloss black
  • GRP and wide rear arches finished in Ford Imperial Blue Pearl
  • DAX cycle wings with custom brackets
  • Modified Headlamp Brackets
  • Fixed scuttle and forward tilting bonnet (unrestricted engine access)
  • Custom nose cone skirt and air intake scoop with recessed '7' enamel badge
  • Marine style stainless steel engine bay vents
  • Stainless Steel '7' Windscreen pillars, Chromed '7' Grille
  • Dedicated Jacking points, with jack included
Steering and Suspension
  • Adjustable GAZ Coilovers all round
  • Upgraded front wishbones (OldTimbo kit), improving suspension geometry and adjustable for camber/rake/trail, etc
  • Camber adjustment sleeve has been upgraded to the stronger steel version
  • Tie rod ends replaced 2018
  • Bottom ball joint dust covers replaced 2022
  • Track rod ends replaced 2018
  • Rear camber correction wedges fitted
  • Refurbished Speedline alloys with new Toyo Proxes T1R tyres (approx 4000 miles wear)
  • Locking wheel nuts
  • Spare wheel
Electical & Lighting
  • Premier Wiring Systems Loom
  • Halogen Headlamp bulb upgrade
  • High level rear brake light (roll bar)
  • Individual rear lights
  • Mini Wiper motor, with stainless wiper arms
  • Side Indicators incorporated into wing mirrors and nose cone
Engine, Mechanical & Brakes
  • Ford Pinto Engine - originally carb, now running aftermarket fuel injection
  • OMEX 600 ECU - rolling road setup at Steve Walford Motorsport
  • Honda CBR Throttle Bodies on a custom DANST Engineering inlet manifold, ITG Filter
  • Adjustable fuel pressure regulator (with removeable guage)
  • Focus injectors
  • Weber 36-1 Crank Position Kit
  • Coil Pack
  • 205 block completely refurbished and rebuilt to 2.1 spec, new pistons, etc
  • Vulcan Engineering cylinder head, unleaded valve seats
  • FR32 Cam, Vernier Pulley
  • Lightened & balanced flywheel
  • Shortened sump
  • New CBS 7" Stainless exhaust fitted 2021, with 4-1 manifold kit
  • STACK Lambda Sensor* (Not currently fitted)
  • New Clutch fitted during engine rebuild
  • Type 9 5-speed gearbox with quick-shift kit
  • Vibra-Technics Gearbox mount
  • Kenlowe Electric 'sucker' fan, with adjustable thermostat
  • Aluminium Oil catch and water expansion tanks
  • Braided Stainless Steel brake hose kit fitted
  • New front discs fitted during build
  • Greenstuff pads fitted 2021
  • New Rear drums, slave cylinders and service kit fitted 2021
  • Custom Alifab fuel tank (approx 40+ litres), baffled and swirl pot
  • New SYTEC Fuel Pump
Interior and Boot
  • Cobra 7 seats in black vinyl with blue piping
  • Willans 4-point harnesses in Blue
  • Drivers seat on sliding runner
  • Momo Team leather steering wheel
  • Fully carpetted and upholstered cabin, in black carpet and blue/black vinyl
  • Custom dashboard, featuring brushed stainless central console, and top-mounted instrument pods
  • Caerbont individual guages - Aluminium bezel, white face. Featuring Speed, Tacho, Fuel, Water temp, Voltage, Clock and STACK Air/Fuel ratio.
  • Rocker Switches for 2-speed cabin/demist fan and fog light
  • 12v auxillary port
  • Aluminium bezel warning lights
  • Aluminium Gear knob and handbrake lever
  • Chrome bezel Gear lever ring with vinyl gaitor
  • Netting storage compartments
  • Aluminium chequerplate foot plates
  • Fire Extinguisher
  • 2-Speed Cabin Heater/Demister
  • Roll bar flyscreen/wind deflector
  • Fully upholstered lockable bootlid
  • Large fully uphostered boot, with built in tool compartment
  • Upholstered spare wheel cover
Weather Protection
  • Custom made removeable hardtop, with opening rear screen (boot access) and built-in cabin ventialtion
  • Removeable, lockable doors for hardtop* Need some rebuilding)
  • Upholstered side-screen/doors
  • Frame work and bracketry for soft top
  • Soft indoor garage cover
Edit: The exhaust in these pictures is not the one that's currently fitted - I replaced this 5" exhaust with a a 7" repackable stainless exhaust last summer. I'll also try to get some pictures of the side screens at the weekend...
Looks like a show car - I could eat my dinner from that engine bay! Although 5000 miles in 20 years is almost a crime against fun 😃
  • 1 month later...
On 11/23/2022 at 4:03 PM, ludo said:
my apologies for being late to the party, but is this vehicle still for sale?
Sorry for the slow response - I haven't checked back here in quite a while.
Technically yes, though there is an interested party deciding one way or the other as we speak. I should know later this week.
  • 6 months later...
  • 4 months later...
