Hi all. Time to change my timing belt but a Google search has come up with nothing. Burtons no longer do them. I know the emax engine is a little rarer than most pintos but I can't believe the belt doesn't exist somewhere.  Any suggestions please?
The 1.6 emax is more properly designated as Pinto variant TL16E, the fordopedia parts catalogue lists the timing belt as have 122 teeth Ford part number 6139911. Use "Ford 6139911" in a Google search and discover several sources for this belt for example:  https://www.123spareparts.co.uk/oem-number/6139911     some also include the tensioner etc   which you will aslo probably need.
https://www.fordopedia.org/parts-catalog/finis/6139911
Hope this helps.
Edited by Sparepart
add
