Engine Swap.
Liam672
Evening Guys! Doing some thinking ahead.
Currently Running a 2.0 pinto in my 2B+ but thinking about changing the engine for something a little  more modern/ up to date.
Initial thoughts are ZTec or Duratec?
any suggestions or ideas welcome!👍🏽
  • 3 weeks later...
I’ll add to this by saying that while fitting a Duratec maybe a bit more expensive than a Zetec it will be a bit easier due to the exhaust being on the same side as the Pinto and I have been told that the exhaust port spacing is very similar so by cutting off the Pinto exhaust manifold plates and welding on a Duratec exhaust manifold plate you get a very cheap 4 branch exhaust.
