October 2, 20241 yr Hi there, new to the kit car scene and I’m looking to get some help locating water pipes for the pinto engine. not sure if I have the proper radiator that’s needed so any help would be appreciated. here is what it looks like
October 3, 20241 yr Hello and welcome to the kit car scene! I have recently rebuild my pinto engine and what I have done was to order generic silicone pipes and elbows and put them together. I got mine from Versatile Silicone Hoses for Automotive and Industrial Needs - Silicone Hose UK Also, if you need ta connectivity diagram, this is the best one I have found and helped me to put the system together. Edited October 3, 20241 yr by ThanasisPolitis
October 4, 20241 yr Radiator Hose Ford Sierra 2.0 Upper for sale | eBay They have bottom and top there is the flex one by gates. Edited October 4, 20241 yr by Daveo
October 7, 20241 yr I am assuming that the pictures are looking down on the header tank of the radiator ?, personally I hve not seen one like this before. Anyway, if it is the header tank then you have noticed the small outlet/inlet on the RHS. If there is no filler with pressure cap on the unseen part of the header, then this small pipe is probably where a seperate header tank is connected. It would be somewhere in the engine bay mounted higher than the higest point of the engine water jacket. It's probably plastic and has a pressure cap.
