Leaderboard
Popular Content
Showing content with the highest reputation on 01/01/2021 in all areas
  1. Hi Alan, As Ian says - what I think they are showing you how to modify an existing horn circuit, using the top switch to give the option of original horn or air horns and the other switch to disable the air horns. If you already have (or had) a working air horn set up on your car I would think you could simply replace your old compressor & horns with the new one. You should then only need to take the wires that went to the old compressor and connect them to your new one. Good luck, Steve
    1 point
  2. What is this meant to be ............... The stearing wheel. not a fuse. I would expect to wire a fuse between the battery positive and the relay pin 30. I am not sure what the power of the compressor is but 15A or 30A would be my guess. The old horn normally uses its mechanical mounting to be its earth (-ve) connection. I am guessing that the stared switch is to disable the air horns. I hope that this helps.
    1 point
