1,032 -
Posts posted by biksz
I wnet in a fireblade kit car and holy crap was fun i wanted bike engine in mine but when i think about getting traction at wheels its no good but very good fun spinning up in third at forty mph
is it same test as it would be for a standard car then obviously age related plate depends on how much gets done?and if i got a 1.8 pinto and changed it for a 2.0 pinto you would not no lol as they look same he he
ouch lucky your hand was not on it
i am thinking of using the original top cycle wing bracket and welding some 15mm round bar on it to support the rear part of the cycle wing but not got rund to it yet so cant put a pic on
hi what is it what goes off at hollowell and what costs are involved as with four kids is tin top or rhs7 an option lol
hi my dad has got 4 wire wheels of a mgb he wants £25 a wheel they need a tidy up can get pics but will need your email as cant post pics on here cant get used to it lol
dam i aminterested in shocks if they dont sell i seem to miss out on these at minute lol
i have a heater blower from my 2b not sure if it works but will check if you intersted.
cheers for that peter i have saved in favoroutes now so i can keep looking back in it for bits cheers
finaly got in garage for half hour or so and managed to get the rad back in and sorted the steering lock thanks to mower man and some helpful tips.just need some hose clips and oil+filter oh and some water pipe for choke then should be able to fire up at last again.
As far as i no its the feed for the choke only so yes i cant see a problem joing the elbow to the rusty one :-)
but looking at your pics you are running manual choke so the elbow and rusty pipe will only need blocking off in my opinionpics sent any more just ask
the first pic the elbow is for the water pipe if you are running auto choke will send a pic to your email of mine and the rusty one is a water pipe will also send pic to your email and yes that is the vacuum pipe
or even cut it so its like a horse shoe cut then twist it round and reweld hope this helps
if the bracket on carb cant be rotated see if you are able to grind carefully around the cable connector and twist it round then reweld it
cant post pics they too big but mine is opposite to the throttle cable attatchment looks like you could have the wrong throttle rod sent some pics to your email
i run a 1.8 pinto in mine will get some pics and try put them on if not if you inbox your email to me i can send that way as i no i can do that lol
got any pics of rear set up paul?
i got same car but i got spax shocks on front of mine
its the s7 with sierra bottom arms one same as mower mans
i got 180 on front and to me they are a bit too stiff so thinking of 120 for front but not sure what would need to go on the back.
you got any more pics of how to do the conversion on back suspension as interested in doung coil overs on back.
just got engine back in car more movement than before on front shockers but one side is slightly higher than other need to no how to alter ride height? sounds daft i no but dont no where to begin lol
Update
had car running at last clocks fitted and working now need to get alternator sorted as think its overcharging so best to get it checked i think.front cycle brackets to sort and make.will keep updated when get more done.
