deano266
Everything posted by deano266
  1. Having a look what is the key ring for. Seems like a bit of a weird key ring attachment haha
  2. Is it not bulky and get in the way too much
  3. Which heater do you use
  4. It's already roadworthy. I could just take screen off for mot
  5. Are there any people in the north west or around Manchester that meet up like other areas
  6. Normally have passenger so a quick shove of the rag in the face should give an idea Not a clue but its how it is as the roof will only just fit that length
  7. Just fitting a windscreen to a pretty built SuperSpec and ran into an issue. The windscreen is practically up to the edge of the scuttle with about 3/4 inch gap. What would the best solution for a demister be or just leave it out and take a rag with me
  8. Hi. Just looking at doing an oil change. What oil does the engine take it is best for it Thank you
  9. Is it me or has the pricing changed
  10. What are the doors and frame made from the kitspares supply. I'm thinking of making my own as then can have my own design
  11. What do people use for wiper arms that attach to a ford wiper motor. The spindle is slightly angled with thread on it if that helps
  12. I'm using a ford wiper motor
  13. I had a focus column and the old stalks that came with the SS got broke. Also the focus stalks didn't cost much
  14. deano266
    Help Needed
    I have a set of focus stalks and need to know what wires go where. So far I have identified: Wiper live Slow wipe Fast wipe Washer live Wash on Indicator live Right hand indicator Left hand indicator. I just need to know what pins they connect up to. Also I have a mysterious green wire that I have no idea what that does but goes to the same bunch of wires as the wiper. Dean
  15. Hi guys what do each coloured wire do on the focus switches as need to wire them onto my SS and can't find a decent wiring diagram that matches up to the colours
  16. Hi I know this is an old topic but can you help with the indicator wiring and wiper wiring for the focus column switch Cheers
  17. How have people attached the side brackets to the windscreen as about to fit one for the first time
  18. Hi I have recently acquired some focus stalks from the scrappers down the road and want to wire them up. Problem is I don't know which wire goes where. I have a good few inch of the multi plug wiring for both indicators and wipers. Can anyone help Cheers
  19. I wondered what that was for as on the focus ito also had the plug through the steering wheel boss
  20. Has anyone come up with a great way to get self cancelling indicators on their hood. I have a focus indicator stalks and everything else but trying to figure out a good way to make them self cancelling
  21. Hi all. I have a Super Spec and i am preparing it for winter. It has never had the wipers installed as they came with it but the wiper stalk was broken and couldnt be used. does anyone know what the multi plug wire are as i knowwhich is the live (bottom left) but need to know what the others do. Also i have a ford wiper motor and the multiplug isnt on the loom and i need to know which female spade connector goes to where and why there would be a loop connector on the black wire thank you
  22. How can I tell if I have a mondeo or focus steering column. I have a 06 super spec and just got some focus stalks. Will a mondeo column stalk surround work with focus ones if it is
  23. Do the focus stalks require the steering column cowl (not the plastic trim) to fit them or can they be made to fit
  24. Hi all is the zero windscreen frame the same as a 2b or are they slightly different
  25. I'm not much of a auto electrician but I have mainly been doing things to just make the damn thing work haha
