Wow, thanks for all the tips, fellas! Can I just pick up on a couple of things, though? I will be using a Robin Hood fuel tank, so is it possible to use the Sierra pump and sender, or will I have to buy those 3rd party? As I will remove the auxiliary warning module, which operates the "low fuel" light, is it straightforward to wire in another fuel warning? I expect the oil warning and maybe some others are operated by that unit, so the same applies? Seems a bit daft to keep the aux warning module, when it tells you stuff about doors left open and so on, which aren't going to be a problem! I assume the lamp failure module is a bit of a complicated luxury which can be bypassed by simply checking your lights regularly... Also, I had two front fog lamps - Are they necessary for the SVA, or just the rear one?
Hope you can help,
Pete
