277 -
12
Posts posted by Pintogogo
Sorry, Try this file
I have attached an excel worksheet of how i wired my fan and temp sender switch on my 2.1 pinto
Hope it helps
Harry
Have a look through Iva manual and from answers on here, but I think standing as proud as it is it will be Ng but recessed into a foam covered dash will be ok especially if it is behind steering wheel where it has less chance of causing damage to face or body
If you glue 5mm foam onto dash before covering the gauges will then recess into foam n be ok for Iva
I've
I've mailed him, Thanks for help
See yous all there guys
Harry
Next meeting at church mouse at Chester le street is Wednesday 27th October (next week) hope to see you there
Hi
Has anyone got a steering cowl top half or complete unit for sale
Harry
I'm coming down as well Alan,
See You There
Harry
Ill be there Alan, hopefully in kit if I finish the wiring n it all works lol
Look forward to seeing you all
Take care n stay safe
Harry
Thanks Guys
I went through all the usual, google, transit forums, owners manual etc etc and decided easier to stick with my sierra stalk
Thanks to all for the help
I've been on net 4hrs googling it and only downloads are on sites that require credit card details as ID just hoped someone on here may have had one
I’m after a wiring diagram for a 1991 to 2000 mk 4/5 transit indicator stalk for my Robin Hood
Hi Alan
Ill be there all being well, and possibly in the kit lol
Regards
Harry
Hi Alan
I was hoping to get there but I haven't been too good, hope to see you at the church mouse later in month
Regards
Harry
Live from fuse box to gauge, other terminal on gauge to sender insulated terminal, sender body should be earthed through tank bolts (ensure tank is earthed to body) and it should work
Universal choke cable (similar to old mini) off ebay £8.99.... spot on, drilled dash,cable through, nut on back and connected to bike chokes with nipple end... 1/2 hr job
Have you checked the carb for 'jellied petrol in float chamber n jets? happens when petrol stands and it goes off, is the fuel filter partially blocked? have you checked the ignition timing & the valve timing? theres lots to do before you go for rolling road session
Had a look at it today, looks like I've dislodged dip stick tube when I've been fitting starter motor and new starter circuit wiring and the oil looks as though its been coming from there
Now sorted.. Many thanks
After fitting bike carbs to my 2,0 pinto i fitted a burtons elbow valve into the crankcase in place of the original breather and piped it to inlet of catch tank, the outlet of catch tank is just vented below car, however on first journey out I was left with a puddle of oil under car and dripping back home to garage, the Oil catch tank is virtually level with the crankcase elbow and the catch tank was empty.
Should the catch tank be fitted lower than elbow or higher? one friend says lower but a diagram I saw on this forum from Burtons had it fitted above rocker cover height
Thanks Peter, you haven't any idea which model will fit by any chance
in Events
I'll be there right day, right time lol
