1,714 -
19
Posts posted by jaimo
Well think got to resign to fact wont make stoneleigh got all back together and misfiring now plug no 3 lead off no change
Got spark
Got compression
Seem to be getting fuel
No oil in cylinder
But no3 not firing
Was only oil causing issue before
Going to get more fuel and have a play but later but time running out
People been asking why change block what have i found
Well nothing yet but as i know its not the head so must be the block
Not got time or money to repair before stoneleigh and going to do it fully
So got a good block from the saviour ivan so just got to get a sump gasket changed all seals then drop in put head on and build up
Then will strip old block and investigate
Well done chris perserverence paid off i bin all day waiting for stu to help lift old block out of mine and drop new one in mite have to get the wife soon she strong enough
But seriously well done mate and chuffed for you
I know a guy dan he does a first class job and does alot of show cars he based hatfield armthorpe junction have u evere seen ruane potatoes on side of m18 just before m180 junction he in there
Theres also ralph at armthorpe ind est he old skool and fist rate round corner from ivan
The spare head i got has a stamp on it but not sure if its a 1. An l or an i
But its not an injection head so not surd what the stamps mean
Has the car you bought not got unleaded head
It was spitting and popping mainly on tickover but once played with abit drove 100% better than on weber 32/36 which was knackered but still wanted a bit of tuning but for never messed with bike carbs i was quite impressed and i wanted to rule the carb out of problems and before wednesday the oil issue never was an issue while driving
What i mean by that was never caused an issue unless left after a run when oil seemed to stick to plug while driving it must of burned it off so lead me to head problem which wasnt solved by seals
Spoke to headmasters and they said all they did was skim and they didnt pressure test head or check guides as trainee didnt put that on paperwork when dropped off as i asked so head could have issues and was going to wait till after stoneleigh to strip due to going on holiday at weekend so wudnt have time to sort but that wasnt an option after wednesday
So hoping that the head swop sorts it if not i either got to swop engine with one i can get hold of till rebuild mine or miss stoneleigh
Dont mean to wind people up and i do appreciate advice just wanted as rich said to enjoy summer then rebuild but that plan out now
Thanks again
I have fitted new head few bits to connect up hopefully its head at fault if not then will rebuild bottom end
And just to clarfy with bike carbs was running great till misfire so hopefully will all be good give it ago tomorrow thanks for input guys hopefully see u at stoneleigh
Well set off to the meet wednesday with new carbs and standard dizzy and bike fuel pump
Was going great it flew and apart from drinking fuel fuel gauge dropping with revs(set up required ) over fuelin
Then half way there cud of swore there was a pop then major misfire
Pulled over pulled number 3 plug lead and end stayed on plug so thought that problem so bodge repaired but still misfire took plug out cleaned al seemed good half mile down rd misfire again nursed to meet
Did same again then few mile home misfire again nursed to stus fitted new plug and lead and drove fine home
So nxt day checked spark and seemed weak so tempoary fitted megajolt what a spark difference started and tick over brilliant hardly any spitting or popping then misfire pulled leads off when got to number 3 made no difference plug fouled again
When engine cooled checked compressions all 4 125psi on cold engine so back to square 1 going to fit spare head and if does it with different head then bottom end rebuild
When look through plug hole the bottom rim of valve its black with what looks like oil
I do believe that sensor to be a vr as dont hall effect have three wires and vr 2 if i remember correctly
The crankshaft sensor on st i believe to be hall
Is it cam posistion sensor
Now now boyz
Not sure when will be there depends how fast the aa get me there lol
Right got cable on on and working
Pump tempoary position and plumbed up in boot ready for roadtest
Popping through exhaust and spitting from carbs gets abit better when warm what best thing to calm this untill gets rolling rd when megajolt fitted
May risk to meet tomorow night aa card with me lol
Thanks nigel i think i spotted where cable fits in carb linkage carbs off again
Ordered a cable from burton power that connects on sierra peal balljoint so that easy and just need a 5.5 nipple when cable comes for carb end hopefully
Starts and revs sound just popping on warm up once warm fine just sprays abit of fuel out carbs
Will test drive wen got cable then if ok will leave as is till i rewire megajolt so fingers crossed
Going to try get there depending if i can work out how to connect throttle cable
Look at this on eBay http://www.ebay.co.uk/itm/381611459498
This is the cable i got so how to connect thanks
Yeah iwas agreeing with you chris
Pinto Problem
in Engine
Posted · Edited by jaimo
Yeah put in 3 different plugs dan changed leads eta wondering if carb not putting enough fuel in to 3 as before it used to pop and spit flame out of no3 carb when running now nothing
Not right up on bike carbs what could of changed from remove and refit
Plenty of fuel in bowl
seems to be getting fuel
Started like it after rebuild going to double check valve clearances again but dont think its that
