710 -
Posts posted by miikae
I'm a big advocate of KISS mode too.
Mike
Remove the sump and then get it welded, as an oil fire would cause you much more trouble than you have already .
Take your measurements before you lift the engine as the mounts will be compressed slightly due to engine weight .
My spacers where fitted to the base of the mounts directly onto the chassis with the two longer bolts .
Mike
I had the same issues so i made two solid 16mm ally spacers to fit under the engine mounts , the oil cap just caresses the bonnet slightly , i used a thinner oil cap i think if my memory serves me right but i may have changed back to the standard one and cut the locating webs a little to lower it a little more into the filler pipe.
Yes a straight edge across the centre line will tell you how far you can go , as thats just what i did .
Mike
your keyboard has got hicups Graham
Mike
The price of a fridge sounds about right
Well i was just there Officer honest , do you think Jack frost took it for a run
Mike
You will be able to report it as stolen in a week or two
Mike
A layby is a no no , try to find a little campsite to be on the safe side.
Mike
ebay item number 8267180437 , thats the tool they sell with there stainless popper kits.
Mike
I would suggest that anyone interested in this subject should do some research into Stan Meyer as this will lead you into places that will invoke many strange ideas , as a year ago i & my son did just that and discovered information that i should not have found as whithin minutes of me reading the info it was removed and never to be found again , why i dont know but enough to say it was very enligtening!!! in very many ways.
Mike
Go to the makers or a local agent as they should have the correct glass and size too plus the edge seals , i replaced one in my Parkray a coupe of months ago it came as a kit with seals etc , £40 i think is was off ebay , even a message to a seller may be helpful as some deal in various makes and models.
Dont ever use window glass .
Mike
Took mine down in 2000 swore never to put em up ever again, bah humbug oh yes oops must take my new 12" flashing tree down twas a pressie from daughter this year just to wind me up he he .
Mike
It may well be for the speedo as i think that some later type 9s had senders for electronic speedos , plus i understand they are quite rare ,
May have been used in some Granada's.
Someone in the know will qualify this i'm sure.
Mike
Al they will send you just enough for a pair of Bermuda shorts i should think
Mike
My pinking problem was due to low octaine unleaded fuel being used without altering the timeing , this was due to not being able to get hold of leaded 4 star , but i would suggest that you use the additive if you are not sure about your valves haveing hardened seats .
You are more than likely not to notice any difference , but your mind will be at ease valve seat wise.
Mike
The only time i forgot to add Valvmaster was on a run up to Newcastle in my old Porsche got half way and the pinking frightened the life out of me when i put my foot down on the A1 , so a lesson learnt here and i never forgot again or had any valve trouble thankfully .
If i remember correctly years ago when i first looked into petrol additives Millars had very good reports but Castrol was easier to come by at the time at local motor factors , so i stuck with Castrol Valvemaster as better the devil you know and all that.
Mike
I use Castrol Valvemaster Plus in my vintage bikes and also used it in my old Porsche for many years with no problems .
Mike
Many thanks Steve just got my in this mornings post , so orange is the must have colour this year eh nice .
Mike
Just a thought on this Al , i wonder if some phone service provider is trying the same trick as rogue elements in the gas and electric providers have been doing ,( i certainly hope not) changing peoples provider without them knowing .
But one never knows these day what scam will be next to hit.
I try not to use call centres at all as they drive me mad getting them to understand the querks of english language .
Mike
If they have 7603 & above it the "E" mark on them they should be ok for the UK , i have just had a look at the old ones i took off and replaced with Halogen .
Mike
I think that you will find that Left means the side it dips to and i guess its a pair made by Wagner in USA that you have , if thats the case then you are ok .
Mike
Try this email address info@greatbritishsportscars.co.uk
Mike
Sliding Pillar Problems
in Chassis
Have a look at this thread http://community.rhocar.org/index.php?show...+pillar+schocks also if you do a search for sliding pillar shocks etc you will find a mine of info , sorry i cant help further .
Mike
