Kerry
Committee
Everything posted by Kerry
  1. Peter, please resend pm. thanks
  2. Hi Guys any suggestions where I can get a surry top for my 2B. Cheers, Kerry
  3. Kerry
    Sierra 8" Rear Drums
    I have a set of discs to fit in the near future, so will have all parts going spare if needed, will be taking drums off in a month.
  4. I purchased a linear motor off a an S type Jag, and have designed a circuit to monitor the current taken by the motor, just need to set it up on the bench to test it.
  5. The idea of going for electric handbrake is the position of the handbrake lever between the seats, its a problem getting to operate it due to shoulder problems.
  6. Does anyone have a drawing of the mounting plate to fit sierra callipers onto rear axle; I am converting from drums to discs before I attempt to convert to electric hand brake. As anyone converted to electric hand brake, if so your thought would be interesting, well it is winter and it keeps me out of the pub. Thanks.
  7. I used a plastic battery box from an early Fiesta,the complete item including strap fitted perfect, pm if you want a photo
  8. Hi Guys, should the pipercross air box cover the whole of the R1 carbs inlet including the air correction tubes, or just fit over the round inlet stack pipes leaving the air correction tubes open to atmosphere un filtered. Thanks.
  9. Kerry
    Rear Suspension
    Hi there, just purchased a 2b with front wish bones, and i am now working through the car to improve on the build. The rear springs which look like struts without the shocker inside are seperate from the shockers, and occasinally the springs rub on the drive shaft. What is involved in replacing springs and shockers with coil over units. Unless anyone can offer an alternative. Many thanks
  10. Hi, I am going to Newark on Saturday to look if there are any 2Bs for sale. Your car looks good and would be nice to look around it if your there. I have left message on piston heads. Cheers, Kerry
  11. Hi , I amlooking for a car and gave a call. told me its sold.
