123 -
Everything posted by Spannerman
John D Not sure about the taboo bit I have made two crouch straps for mine out of one "v" sabelt without any problem, use a red hot knife or hacksaw blade to cut it & seals it at the same time so it will not fray. you can get some strong thread ( can not snap it by hand) and stitch as per the original stiching they seem fine. I now some one has altered his belts ok as well (no name just in case it is taboo) cheers Kevin
Hi Joey We now know why your cars not finished! You've been moonlighting in Fuengirola!. Does your dad know about this Cheers Kevin & Gayle PS Hope this doesnt get you into trouble! Ha Ha
Hi Barry Velly intellesting han phunny ! Cheers Kevin & Gayle Ps Some very good artwork.
Hi Just fitted coil overs to the front of my 2b from Dampertech Spring were 9" 2.25s 250 lbs rating I thinck the shocks were 13" open & 9" closed Can check paper work if Req Had some problems with the top wishbone clearing the spring 1.9 may be better??? Cheers Kevin
Hi All, We're having ago at making one but did not see this thread until now, intend to bring it to Stoneleigh, it is of a different design and extremely lightweight material, hope it holds up. Cheers Gayle & Kevin
Hi All Bit of an odd one I know but my 2b plus has been leaking water from the chassis. When it rains or I wash it leaks for days / weeks after so I decided to investigate, see pics I drilled up through the box section (two skins) into the bottom of the chassis tube to allow drainage, I got about half a pint out of each side. Mine is a stainless chassis so the water is not to much of a problem but mild steel One will soon start to rust. Hope this is of interest to some one? Cheers Kevin
I Havent Time To R B T P (Rather build than play) clever Rizla fun for some
Hi Bill Never mind , but please be gentle on your 2b build (by the way you know joey only does keys) Big Jim has one for me instead see you at Stoneleigh Cheers Kevin Ps Rizla I would buy a new one but I am on a Budget ,lots to do lots to buy, You Know what I mean ( road tax ,insurance , mot, fuel Etc,Etc )
We're not too far NW just quite west of Lincoln! Being in Runcorn Cheshire, doubt if we're the nearest Hoodie group to you, Ian and Carol whom we've met a couple of times at shows etc also live in Lincoln, not sure whether they use this board. Cheers Kevin
Hi Yellow Peril, Cruise - what do ya mean Cruise!! does your hood not go too well then?? :boohoo: We're across in the North West if you feel like a 'Cruise' over any time, kettles always on. Cheers Kevin & Gayle
Hi Bill & Joey, Yes, Stoneleigh will be great but will you have room for it in the 2B?????? See you at the Bar. Cheers Kevin & Gayle
Hi Bill, Thanks for that I'd like to take you up on the offer, are you going to Stoneleigh, if so can you bring it with you? if not can you please post it and I'll sort out the costs with you asap. Hope you and Joey are not idling away your time too much, you should be working extra hard so you can put the big smile back on your faces like you had in Wales!! Cheers Kevin
Hi all, Can anyone help - been searching around the scrap yards recently for a thermostat housing for a pinto without any success, has anybody got one going spare? Cheers Kevin
Hi Miked318 Thats a big sheet (4X8?) but what is the 'Have Sex' above it? I am intrigued! Kevin
Hi We are in Runcorn just north west of south Manchester!! We get out and about most weekends if you want to meet up There is a North West section of the RHOCaR, which is very active for outings and will make you very welcome for more info contact Jim Stott NW Sec. Give me a shout my Email KLp56@tiscali.co.uk OR 01928 712573 Cheers Kevin & Gayle
Sod the mid life crisis just wanted a kit car 47 and the wifes the same and love the Hood just as much or more than me at times! Cheers Kevin
Hi Tim How about making it a bit of a soc as well for the weekend it may encorage more to come? Cheers Kevin Ps we have sent the form for Le Mans to mick but the post is up the wall shall I email it to him?
Hi Jostan As far as I am aware the ones I have are green springs they are supposed to be rated at 320lbs, as to the open closed length I'll have to measure or you can measure up yourself depending on the travel you require, the standard ride hight is approx 6 inches. I find that mine bottoms out on 320lbs springs. Anybody else got any comments? Cheers Kevin
Hi Mat I think the new logo looks good But how about a new pic of your car May be with some suspension or have you been doing other things Cheers Kevin
Hi I have a Rover Factory Manual for a Rover 800 it may be for the T not sure will dig around in the hole (garage) tomorow Cheeers Kevin
Thanks Les Will have a play at the weekend. Cheers Kevin
Hi all Has any one info on dim dipped beam (Very Very Dim), main is fine I know its wired wrong but cant sort it :angry: Cheers Kevin
Mick I wish this offer of membership had been available in August could of saved 15 Quid and spent 20 instead and gained a year But I must say it does not matter when you join, you can reap the benefits immediately of this excellent club and site Cheers Kevin
John Are your "mine straps" imported from Germany then! Vorsprungtechnick ????? or something like that. Kevin Ps If my misses wasnot ckeking mi speling. im sure you may be comenting¬&^)(*£
