2,726 -
14
Posts posted by chris n
Online MOT Inspection Manual Rules
http://www.motinfo.g...m4i00000001.htm
Brakes can be found under section 3. Discs and pads are under 3.5 Mechanical Brake Components.
As said before if your not happy with them change them out for a new set, all it going to cost you is the price of the part and a couple of hours of your time. Job done
If memory serves me correctly you had to use an ally bell housing with an ally sump, that way the cable would fit right,
Or you could try fitting one of these
Updated 23rd March (304)
Have to agree nice cars the rest is so wooden.
Fifth Gear has now started again on History HD (529 Sky) on tonight at 9.00pm if you need more of a car fix
I would start by stripping the door card off and the rubber film behind it (can be very sticky and messy to remove).
Once you have access to the window regulator motor check all the wiring from the motor back the door multi plug on the A pillar to see if there is any cut/ breaks. Also plug the switch back into the loom and see if there is any sound coming from the motor, if there is a sound going both up & down it may just be the case of a stuck armature.So give it a gentle tap with a small hammer (not caveman style with a club lol) with the switch in the down position and see if you have any movement.
If no joy than as Nigel said the car needs to be plugged into Ford IDS to see where the problem lies.
If your talking about the interior light playing up:? There is no separate switch as the switch is built into the door lock itself. Is it only doing this when the passenger door is open? Check the loom from the lock to the door plug but more likely to be a short in the door loom.
http://www.youtube.com/watch?v=HxgZAqiiRhY
Here is one of Fords trouble shooting videos to electric windows
HTH
Updated 2nd March (292)
Makita 18V drill for me. I must have spent a small fortune on cheap cordless drills over the years.
Sounds like its got an air lock in the system. Try bleeding it with a pressure bleeder to force it out
Updated 16th February (274)
Updated 8th February (265)
Updated 1st February (258)
Both the same seal and part number
Updated 25th January (245)
2011 Ford Focus has cables for gear linkage so it may be that the locking ring on one of them at the gearbox end has come
loose or the cable has worn in the inner lining known fault, ( changed loads of them.)
Remove the air box from the car by removing the intake pipe from the air filter undo the rubber ring at the front by the
slam panel (if fitted) and the air box should just pull out of its mountings.
You should have room to the see around to the back of the gearbox to the cables and control arms and check if the outer cables are locked into there mounting brackets.
If all is ok with this then it may be the gear lever remote itself or a problem within the gearbox.
A puller is the way to go to remove the pulley. Had a friend of mine try to remove the pulley off his engine to change the oil
seal with a couple of pry bars and ended up cracking the cast aluminium timing cover.
Then after the pulley was removed left me with the pig of a job getting the cam belt bottom sprocket off to change the cover lots of heat and a few choice words.
Top tip once you have the pulley off give the end of the crank shaft a light coat of copper grease, as it will help the next time you need to remove it to change the cam belt
Updated 18th January (228)
Updated 13th January (207)
Very true Bob you need the 0's with out them you would soon go down the pan.
Here someone who loves a 0 or 2 or 3
Same here order cancelled.
Now I know why I don't have an account with them
Updated 12th January
If it had been an IVECO the cab would have come off as well with all the Italian rust. Glad I don't have to work on them
things any more.
If I had a pound for every set of door hinges I changed I would have my own Island in the sun
Cheers for this, was in need of a low profile jack to save putting the big 3 ton jack in the back of the truck.
Also ordered the trolley too, as I did have an account with them plus was out on a job I call SWMBO who has. to order. Job done
Updated 7th January
Mine as well really quick thanks to Chris or is it Becky who is plowing through them.
Glad they're all arriving safely. I do have help, it has to be said Becks says its a welcome break from studying.
When Do Brake Discs Fail Mot Or Get Advisory
in Chit chat
The Diesel engine in the Ford Kuga is a Peugeot unit. Service time about 2 hours for the whole car
A 27mm socket and a long extension bar will get the filter housing undone.To get the old filter and housing out from the engine bay you need to remove the large
intercooler intake pipe off then push it out of the way to one side. Something to remember for the next time Bob
