2,346 -
8
Posts posted by Dave R
What does the duratec flywheel weigh?
I have removed a section of the floor panel at the diff end.
Undo the 4 bolts connecting the prop to the diff and the prop shaft slides forward then down and out.
followed quite quickly by the gearbox oil
Agree with the above
wrong oil could also do the same, and as its colder it will be thicker too
i am guessing it was andy
yellow rh spotted this morning as i was going to work at 9-30 ish
on the clapham bypass near bedford heading towards rushden
anyone on here?? you wouldnt have noticed me, as i was in a van going the other way
did mine... hinges on rose joints, totally removable in about 2 mins
do so photos if you are intersted
should be up for last 2 dates
With the duratecs. Some of the thinner ones have wiped out the engine thrust.... not sure what the series is like for clearance behind the crank spigot bearing
The ones I have seen are 20 to 25mm..... suggestion... Offer up without the bellhousing.... see how far it will engage... measure the distance.... allow say 5mm extra so you are not pushing against thrust...
Not seen many Any?? Rh that fetch 8k... where In beds are you? If you want a 2nd opinion
stock 2l is good for 190 on std internals, and throttle bodies
weak points are pistons....
they last about 2 years with my driving style on the road
Mk1 has a square hazzard switch, round on the mk 2
wrapping yourself will cost more.... rekon to scrap the first 2 attempts....
just my personal experience, and i didnt try something as complex as the nosecone
Mine not showed yet
get someone else to do it.... its not a lot of money, and saves sweeping up afterwards
if you do decide to do it, i have a few bags of blast media, yours for a few bottles of beer
what he said /\
me too
something similar wiped out the oilpump and cam bearings on mine.....
are you intending getting on the rollers? would be interested to see what bike carbs make compared to jenvey
jenveys and omex on my duratec he
hurt at the time but the 190hp helps everytime i drive it
possible bottom breather leak ??
where do the breathers connect to ?? inlet or puke tank... is the valve intact in the bottom breather- if it goes to a tank, then it wants removing....
picture of where it appears to come from would help
Fuel Level Sender, X-Flow Clutch, Duratec Flywheel+Clutch
in For sale
about the same as what i have already
