Lightweight Help
BigLee
  • Replies 47
Guest ScotMac
For the main two thru bolts, you need:
2 x 12mm x 35mm thru bolts
2 x 12mm Nyloc nuts
4 x 62mm packer tubes
8 x 20mm large "spread" washers (4 will be cut to fit above square section on bottom thru bolt)
For the two bolts at the mainshaft end of diff:
2 x 12mm x ?? bolts
12 x 20mm large "spread" washers (5 to space each side, and 1 for the bolt on each side)
HTH. Cheers, -sm
