About Time
Snapperpaul
Just about finished after 4 long years, 2 without a garage, a few little details to finish for SVA but in essence its now complete
Won't be doing any work on it today as it is raining, tommorow maybe.
Heres a few pics.
Very scary now I am so close, tow bar to be fitted to the Galaxy and hire, borrow, buy a trailer, take it to work for a shakedown on the runway.
My cousin is a lorry fitter and has access to VOSA calibrated rollers so may be able to get the brake balance and axle weights sorted.
Well done mate. :D I've just heard the weather forecast, it's going to rain everyday from now on ;)
Good luck with the SVA
What ever happened to All this talk of Global Warming , Has Gordon Brown /Darling put a stop to that too !! As not taxable enough therefore not a good thing .
Mike
Guest Bazwaz
In your pics it looks like you have the older roll over bar. Is this okay for sva? i hope i'm wrong but i thought it had to be of thicker diameter.
Barry
I'd also heard that Baz but the only reference to it I can find in the SVA manual is in the seat belt anchorage section which I don’t think is applicable unless the tester thinks that the roll over bar
will provide strength and spread the loads effectively into the chassis.
Note: For guidance roll cages should ideally be
manufactured of CDS steel tube dia 45mm x
2.5mm wall thickness OR dia 50mm x 2.0mm
wall thickness. Bend radii should exceed 3 times
the tube diameter. Where tubes are ovalised
during bending, the ratio d/D should not be less
than 0.9 (d=small diameter, D=larger diameter).
Guest gavinc
is that steering wheel sva compatible....
looking good paul..
cant wait to go to the sva with you.
and take the "p" like you did..
