Will I Need A Brake Servo?
2B Zetec 2ltr Discs front, Drums rear.
Just wondering whether I should use a servo for the brakes. I was not going to use one, having been used to an Elise S1, but I seem to be seeing a lot of installations recently with the servo retained, even the RH DVD shows one having been fitted.
PS: still looking for the adjuster bits and pieces for the rear drums.
I dont have one and it means you can stamp hard in an emergency. :D
Some peeps say you can feel the braking better without one
Worked well without one in the Elise.
It only seems to be there to take up room under the bonnet of the 2B.
Try an e-mail query to GMS Capri Spares.. Their website lists only a tiny part of the stock they hold. Sure I saw them on their stand at Stoneleigh.
With or without servo is down to personal choice.
As Nigel says it really is personal.
I am much happier with our car without one, used to scare the c***p out of me on bumpy Dales Moors type roads and even more so in the wet.
What brake master do people use when you don't wish to have a servo?
I am trying out a remote servo as there is not alot of space under the bonnet, not got the car running yet but will let you know how it works when I do.
as you have a split system don't think you can use a remote servo with out upsetting the balance to much.
i am in two minds about a servo, mine has , and is too sharp and you need to remember to apply carefully. so not to clever really.
i would like a bias pedal box, after finding the correct master bores should be a big improvement. plus i should get a bit more leg room.
woolly
Thanks Nigel,
Will email GMS Capri Spares or better still, will give them a call.
I have decided non-servo with standard "Dual Circuit" Sierra Master Cylinder.
Thanks Nigel,
This is the way we went, all you need is a different pushrod from pedal to cylinder.
Bought ours from Tiger racing, about a tenner.
If you give them a ring and tell them what you are doing they will know exactly what you want.
I used the standard Sierra manter cylinder without servo in my S7 - works very well. I made up my own pushrod.
Running a 3a with no servo just fine. Cut up the old servo for the push rod (clips to brake pedal). Mounted master cylinder (suplied RH) with a bit of box section to take up thickness of servo. Ball end of push rod just sits in master cylinder cup, can't fall out with pedal right back. Run one brake pipe to rear through unmodified mini brake limiter, spare outlets an master cylinder and limiter blanked with blead nipples (limiter has concave seat but seals well). Why run without a servo? By the time I had the engine positioned, pedal box mounted (6ft 4in) and the stearing shaft to miss alternator I'd run out of room for one. Drive like a motorbike, apply the brake and squeeze the pedal (good feed back). Can still lock the fronts no problem, PS: passed SVA with good front/Back bias (can adjust by modifying limiter -do a search or post).
inmyho you dont need a servo on a seven , you may get a twitch on the bum the first time you try to stop withought one but you soon get used to it .
with a servo the brakes will lock up at the first time you use them in anger and you have no control in that situation
panic !hit the brakes with one and a mess will ensue .
just my opinion .
graham
i use my car as an everyday beast, and i am used to the assistance. I tried it unassisted for a while but i got tired of pulling up on th steering wheel to get it to stop. It's very much 'each to their own'. That said a smaller diameter servo cylinder could match up nicely, but I'm only hypothesizing there....
I'm with Andy (Grim) on this one. I like the servo but it is just what you get used to.
