2b Rear Double Wishbone Coversion
Guest mighty2b
I havent seen one.
The rear design of the chassis is all about using the Sierra DeDion setup,
I looked at modifying it when I changed the front sliding pillar to wishbones, but unlike the front chassis, the rear chassi has no obvious pick up points for the wishbone pivots. All in all a job too far really. Probably simpler to re-chassis the car completely....but that would need a new SVA/IVA test....probably!
Yup, thats the conclusion I came to, but it looked like I would have to move the diff rearwards to get a suitable pickup point for the front of the wishbones. All in all loadsa work & very little noticable improvement.
Get some sticky boots, & a decent pair of coilovers & I guarantee you will be astonished by the handling already available to you.
Bob
Guest mighty2b
Good pics,
Liking the cossie engine, must really fly.?
Anymore pics of the wishbone set-up please with the arms fitted.
thanks
Edited by mighty2b
When I finish my front suspension upgrade (tie bars) and engine gearbox fit, I plan to look at the rear of my 3a.
Thinking about a modification of the Haynes rear cradle that can be bolted up using the current mounting points for the Sierra A frame, with extra points to take in the roll bar and possibly the original shock mounts.
Probably happen next years winter mods.
Hi Paul
That is like some one said is amassive amount of work.
Will be interesting to see how much improves things.
From photobucket if you ctrl +c the img box then come to here and ctrl + v
you get the image like this.
Hths
I know it's a lot of work but until I get another project it gives me something to plan, keeps my interest going.
I spent well over a year planning and building the Pinto, I am now researching manifolds and exhaust system harmonics.
If I do complete plans for the rear wishbones that will be about as far as I go with the S3
