Iva Test Date
Guest sandy77uk
  • Replies 34
Guest sandy77uk
aye megadoo, we shall have to sort something
i did want to speak to you about wiring, i use a variable fan controller with a built in relay, this is fitted right behind the radiator, I've been told that when hot and the fan is on the car could struggle to start due to the current being pulled, my question, could i break the earth wire and run it into the cockpit and fit it to a push button, so when I need to start the car i can break the ear but the button, start the engine then release button to reform earth?
You could, but perhaps a neater solution would be to use the starter signal to throw a relay that breaks the fan circuit. As soon as you stop cranking the fan will cut back in again. It's easy to do but when you bring your car over to show it off I could do it for you if you want?
