Outside Cover For 2B
Guest paulrrh2b
Hi All,
Due to building work, my 2B is going to have to live outside for a while.
Can anyone reccomend a very good quality, heavy duty cover, I can use. I have seen the £30 quid ones and they wont last long.
All help appreciated
Regards
Paul
Ive been using one from machine mart till i got a garage sorted. held on with bungee cords..not included. been spot on and dry
I'm still using a heavy weight lined one i bought off ebay some 5 yrs + ago and it is only now starting to crackup in places due to sunlight, kept in place with 2 very long bungie cords i made up to rap around to prevent the high winds blowing it away.
I bought one of those £30 ones a couple of months ago for my MX5 which i thought would be the same but alas no, as it is only half the weight of the old one i have, certainly not as good as my old one.
Guest paulrrh2b
Thanks Guys,
Looking at a quite expensive one for a Caterham. Anyone know if it will fit?
Caterhams are quite a bit smaller than a 2b.
Just what i was thinking as the 2B is quite a big beatie in comparison.
I have one from CBS and has been on and off the car loads of times and does not appear to be suffering at all! Cost around £35 and fits a 2B nicely.
Guest paulrrh2b
Hi
Yeah I have used one of those types in the past and it ended up holier than a church!
I have seen the tree / four layer type, such as the ones used for caravans winter storage, just need to know which one is best / to go for??
Cheers Guys
Paul
I have one from Hamilton Classics, it was about £100 but has lasted 5 years and is only now showing signs of wear, its a snug fit as its for a Caterham and i also have clam shell wings. well worth the money in my opinion as my Exmo lives outside.
I've also just bought a Halfords Advanced Small cover for £65 and use this over the top of the Hamilton one. this is a bit big and i'm thinking of borrowing a sewing machine to tailor it slightly.
From experience the £30 ones only last a winter or a few strong gales.
Just finished building a 200sq. foot greenhouse with a "Car Flap" in one end; should do nicely for when other projects make Florin homeless.
Guest paulrrh2b
Thanks Dave Ed
I have contacted Hamilton and they are sending one to me today. Yes, the cheapy £30 quid one on it has lasted three days!
Ill let you all know how I get on when it arrives
Regards
Paul
Got a garden type tarp now, which seems quite good.
I would be cautious of that, you want a breathable cover surely?
I'm lucky- mine is covered inside a garage so its not such a problem although I still have a breathable one.
Guest old_timbo
I put a cheap cover on my 2B and it messed up the finish of the polished stainless when it rubbed in the wind. Has any one used a Poly tunnel like this?
http://www.ebay.co.u...=item19c56db76d
Looks ideal for a temporary garage if it is robust enough.
