Garage Clearout
Guest scrabster
Guest scrabster
Been having a rummage and decided these can go .
pinto fan with viscous coupling, £10
2x flexy water hoses 32mm bore and 400mm,500mm long £10
rad1... zero rad ,coolman type,had an extended neck soldered on but easy to put back £10
rad 2...same size as coolman rad but twice as thick,outlets opposite to coolman 28mm outlets, fit v6 or v8 maybe? £15
bonnet scoop from mitsubishi pickup, fitted one to my zero,£15
3x 12v fans, 1 is 10" dia blades , 2x 12" blades, £10each
small led front indicators carbon effect £5
iva extended indicators and spring back mirrors £15 the lot or £10 a set
small carbon effect mirrors £5
all items posted at buyers expense or you can collect if you wish. ask for a pic if you want and i will dig camera out.
regards,jess.
Guest scrabster
hi, i fitted mine with the lower post-3394-0-12961200-1359928258_thumb.jpg part removed with the angry grinder, it matched the curve of the bonnet better, original fixings were 6 x 6mm bolts , 2 of these removed which left a neat square hole to be cut in bonnet and 4 holes to be drilled,the bit that was removed left the scoop just resting on the outside edge of the scoop and with the rubber seal left it nice and neat.the black bit you can see in the pic i covered with carbon effect film just because the paint looked a bit thin.the bit i removed made the bonnet pull up flat with the 6 bolts and looked out of shape so i cut it of and made a better job of it.hth.
regards,jess.
Guest scrabster
just an update, bonnet scoop, iva mirrors and indicators, carbon effect mirrors,12" fan,hoses, all sold.
regards,jess
few peeps interested in bonnet scoop, if i get another i will post on here.
