Where To Get Press Studs
alanrichey
I need to drill out some of the presss studs (that the wet-weather gear clips onto) on the back of my Superspec to do some work on the fuel filler. I gather they are easy enough to replace but so far all I have found on E-Bay are self-tapping versions (See Item 221046648254) and picture, and I need pop rivet versions
Can anyone point me in the right direction ?
Pop across to Woolies at Market Deeping:
http://www.woolies-t...urable-dot.aspx
Another excuse to take the car out!
Nigel.
Thanks Nigel, that's a great suggestion. At least that way I can show them the car and make sure I get the right things. On E-Bay it's going to be guesswork :)
Thanks for the advice. I may be seeming a bit dense here but having never done this before my problem is I have no idea how these are fastened. Most of the press studs I am seeing on the net/high street are either self tappers or require access to the back side to be squashed into position, These fasteners are on the carbon fibre back plate and appear to also be fastened through into the stainless steel chassis so I have no idea what the backside looks like or how you fasten them without access to the rear. I assume 'Woolies' will explain it to me.
  • 8 months later...
Guest petelee
Hi Guys!
I'll have to ask Nigel to show me how to fit them too, when I come to fit my weather gear later in the year!!! Luckily, he's only just up the road!!!!
Pete
Guest JammyJim
They are press studs.lots on e-bay, the part fitted to car comes as 2 piece but you don't use backing plate, just rivet in place.
Edited by JammyJim
