Zetec Conversion
tractor
im after a full gasket set full cambelt kit new water pump smaller oil filter and maybe some internal bits trying to locate stuff with engine code but as per the code on engine completely different to what it should be it starts with ngb cant find that anywhere
Guest alfaGTA
Damn i missed that engine code! Must read better! Eurocarparts have a vehicle identification box where you can select your car year and model, as Nigel said you are looking for 98 onwards mondeo, think the duratec engine was in production from 02 onwards. There are lots of short oil filters available that fit, i used a v6 cologne filter on mine(short and fat)
Reasonable oil filter is Champion C104. You can go smaller but the above has the right thread and base diameter and works.
Water pumps on 2.0L blacktops. They work with the wrong rotation and there is no swap. Unless you count the American one which is very hard to get hold of. Add an idler wheel and run the waterpump off the back of the belt like everyone else. (Swapping water pumps is for escort silvertop 1.6 pump onto mondeo 2.0 silvertop engine which reverses drive direction just fine.)
