Steering Rack For Exmo
Guest mcinallygsxr
Guest mcinallygsxr
iv seen a few on ebay from about £70, is there an upgrade or quicker steering rack available without throwing the budget out the window?
thanks, james
Guest mcinallygsxr
i assume its just the original sierra donor rack???
yeah at £70 its maybe not worth getting it welded, did the quick rack make much difference to how the car drives?
thanks james
Guest mcinallygsxr
yeah doubt anyone would want my rack for reconditioning, iv seen a few older posts about power steering racks been used. has anyone done this and is it worth while?
thanks
The P/S rack is quicker than std. and cheaper than a bespoke Q/R, but needs a fluid system of sorts attached, cut and shut pipes full of fluid works.
I use a Sierra PS rack. As Ian said, I have joined the pipes so its a closed circuit, & full of fluid.
It does not fit a standard column, the pinion on the PS rack is longer & has a different no. of splines.
But well worth it.
Still dont know what rack the Exmo has.....
Guest mcinallygsxr
surely an exmo owner will be along shortly to confirm which rack is fitted as std.
i will phone local motor factors tomorrow. cheers
