Wiring Loom Diagrams
Guest Kamran
Guest Kamran
Hi all, can any one help, i am building a 2b a unfinished project,it came with i think an early gbs wiring loom but the colour don't match vg loom,e.g. temp. Sensor orange wire, oil pressure switch yellow wire ( 3 relays / 6 fuses, wiring only for nsf headlight) and no instructions. I've been trying to wire sierra stalks for three days solid no luck ahh!!!!
The wire colours i have at the stalks:-
Green/yellow
Green
Orange
Red/green
Green/black
Brown
Grey/red
Red/white
Yellow/blue
White
Black
Orange/black
Orange/white
Red
A diagram would be good as i can't find the one with these colours. or if you can tell me where they go on sierra stalks. If anyone can Help will be really grateful,thank you!!
try this
green yellow 49a of column switch
green, secondary ignition supply
orange 53c washer switch
red green ?
green black R right indicators
brown constant live
grey red 53b wiper switch
red white starter wire but check at starter as colours have been reversed on some looms
yellow blue 53 wiper slow
white ignition live
black ground
orange black 56b to dip beam relay
orange white shore its not white orange which is 56a main beam relay
red 58 side lights
Guest davidm
I'll have a go, but this is entirely at your own risk - no liability accepted!
Flasher/hazard switch
Pin 30 Red
Pin 54 Black
Pin 49 Black/Red
Pin 49a Black/White
Pin R Black/Green
Pin L Black/White
I'll get back to you on the others
Guest Kamran
Hi tried the above wiring.
Hazard switch when switched on keeps lights on constant no flashing.
Headlight switch only beam flashes, no lights come on.
Indicators won't work.
Changed earth on main beam relay to switched live from ignition, used that earth to top of stalks.
Any ideas
forget earth switching, that is what ford used on some of their vehicles, the loom is not designed that way. wire them up live switch. or you will have to change the relay circuits.
I must apologise, I just answered your question on what the colours are for, you will need to supply some lives as well to complete the circuits.
terminal 30 on light switch and indicator switch, terminal 15 on headlight switch and terminal 31 ( the left spade on top of the right switch) will require a +12v feed.
Brown is a constant +12v, White is ignition switched +12v.
you may have a problem with some switches with the washer pump staying on, but there is a simple mod. PM me if required.
Guest Kamran
Hi so shall i change the relay back to normal factory setup, and then add these lives in? Should i use switched lives or constant? At the moment i have a constant live in 30 and earths in 15 & 31, so ill change these. Will try in the afternoon thanks for your help
Guest Kamran
Hi tried this but has had no effect. Main beam stays on so i changed realays back and hazards will work but stay on, not repeating, relay sounds constant. Please any advice thanks
pretty certain Karmen has a post VG loom, at least three versions, but all very close.
there is one relay plate two are fitted with main and dip relays the other has the flasher unit.
the loom can work with any of the ford column switches.
to confirm loom relays should be wired as below, if not we have a different loom.
relays dip beam relay 30 blue white OSF head light (main beam) 30 blue white dash main beam warning light 85 white orange headlight switch 56a 86 black earth 87 blue white fusebox main beam relay 30 blue red OSF head light (dip beam) 85 orange black headlight switch 56b 86 black earth 87 blue red fusebox flasher relay 49a green yellow column switch 49 green 31 black earth
sorry, this may be clearer
86 black earth
86 black earth
87 blue red fusebox
49 green
31 black earth
Edited by knights_templar
