2.0L Zetec Running Rich
Guest b3nny
My black top seems to be running pretty rich, I had the plugs out at the weekend and they where pretty black and the white ceramic had cracked on 3 of them, is there anything I can do to try and lean it out or is it a case of getting it on a RR to see what's going on?
Although it's quick I dint think its running to its full potential, on a previous dyno sheet that a previous owner it had done it says,
Suspect choke stop
And big advice 36mm or 38mm would need to be jetted back down once replaced, could this be anything to do with the richness and the fact it seems sluggish once around the 100mph mark?
Guest b3nny
Just been doing some reading, I have a fuel pressure regulator and a electric fuel pump, the regulator is from CBS and is set to 3.5 on the dial is this to much, ove read that a pinto should run around 2.5 psi would this be the same for a zetec running 180bhp?
I was told by omex that you set the pressure, within a certain range and the carbs/itbs and engine is basically set up to that.
Mines very rich at the moment but is rather that than lean.
Edited by flameredturbo
Guest b3nny
Indeed, much rather rich than lean, but to be it feels that because of it running right I'm losing performance on WOT and top end, 3.5 on the dial I assume is 3.5 psi? I'm thinking this maybe to high checking in mire fuel than needed giving me my black plugs and less performance?
It will really need a session on the rolling road with someone who understands the carbs, don't get too excited about the fuel pressure issue, if it was too high fuel would be flooding out of the float chambers all of the time.
Guest b3nny
From what was said on the last dyno print regarding the venturis, could it be that the ones fitted are causing it to run rich and this is why it was mentioned on the dyno report?
My zetec is on 45 webers and runs perfect. You will be getting 175bhp if is all is well and tuned correctly. Mine runs 36mm chokes and 140 mains. On 45 mm chokes and and 155 mains it ran 190bhp but was a pig on part throttle. It runs sweet as from. Tick over to redline. Check your carbs have 5 progression holes these are the only version of webers that run right on zetec.
Guest b3nny
Well the last dyno print out read 170bhp with bonnet ans gauzes fitted (now running itg filter), how can you tell if your I'm running 40 or 45, and where abouts are the progression holes?
It's written on the carbs what they are, if not take a choke out and measure the o/d Google weber progression holes and you will find exploded diagrams of where the holes are. Under a screw near the manifold.
Edited by DanE
Guest b3nny
Thanks for your input Dan, one thing I have noticed is that when I have removed the trumpets the part behind is embossed with 40, is this anything to do with the carb,ventruri or something else I'm yet to learn lol.
