Welded Diff- Will It Pass?
Guest Joe_burtenshaw
It will fail IVA as they do side to side individual brake tests followed by axle test.
Obviously you have never driven a welded diff on dry tarmac, even worse in wet!!!! :80: :80: :o :o or bought tyres as you will wear them out very very quickly.
Can I ask why you have fitted a welded diff ??
I used to run welded diffs in my bangers & hot rods.
Obviously we ran on shale & they were great for kicking the rear end out
on a loose surface.....but I tried one on a tarmac surface....just once...never again.
LETHAL.
Thanks guys! Glad I asked! What I have at the moment is a lexus is300 engine and rear diff, but it isn't an LSD, so will a sierra diff work and hold the power? Or does anyone else know of a suitable LSD? Many thanks joe
The Sierra diffs are pretty strong, & theres an LSD version fitted to the 4x4 & Cosworths.
Most common ratio is 3.6, there was a 3.38 (IIRC) but theyre like hens teeth.
What ratio is the Lexus? I suspect it will be pretty low .
IIRC you fitted the whole Lexus rear end?
You may be better to source a standard Lexus diff.
You'll be a pathfinder fitting a Sierra diff in a Lexus frame
