Alternator
tractor
Hi.
If you still decide to use the small alternator the connection is a type 4.
The plug to fit is available from Simtec Motorsport electrical Part No Con 354 comes with pins and seals.
Contact www.simtekuk.co.uk
Mail. sales@simtekuk.co.uk
Tel 01706 854 857.
Hope that helps as if used it reduces the chance of failure if you use a home made plug and silicone.
Regards Allan
if you look at the pictures with the denso alt you can just make out that its flat bar bent to fit must have taken
a
bit of time to get right it was already fitted to the pinto courtesy of ozz for the pinto alt which is bigger and heavier I have had to make another bracket to hold it at the back
Edited by tractor
