Rear Light Wattage
nelmo
While preparing to install my rear light clusters, I may have ended up getting the lens units swapped around. In each unit, I have a 5W bulb and a 21W bulb - is there any standard for which of these must be the brake light and which the indicator?
Despite searching the web, I cannot seem to find an obvious answer to this seemingly trivial question (and nothing in the IVA manual either).
Edited by nelmo
Indicator also 21watt.
Is the stop and tail light not combined 5w and 21w in same bulb?
Jez
Ah, that's possible - I remember 2 wires going into 1 of the bulbs but didn't think to look at the filaments - I'll check it tonight - many thanks...
Guest snowy2
8. Wattage–
(a) A stop lamp fitted to a motor vehicle first used before 1st January 1971 or a trailer manufactured before that date and a stop lamp bearing an approval mark:
No requirement
(B) Any other stop lamp:
15 to 36 watts
9. Intensity:
No requirement
this is an excerpt from the C+U regs...only stop lamps have a wattage.......15-36 watts.
