Apparently they did??
Other option is to fit an atb but wouldn't know where to start with that and expensive enough without paying someone to fit!
after an LSD with push in shafts
Excellent mod for a seven is a viscous slipper but they are getting rarer and expensive and the push-in shaft ones are like hens teeth. Be not dismayed however because it's easy to change the inner tripode joint on the driveshafts to take a lobro so you have a hybrid type that bolts up to a flanged diff. Job done. Of course if your donor had a disc rear end then you should have lobros already.
