Sign in to follow this
Friartuck
Quadrant Tension Spring
Help required please
Looking for a tension spring 40mm x 18mm (actual spring measurement ex hooks) have seen a couple of springs on Fleabay but they do not quote size (have sent seller an enquiry) they are for Granada, Focus & look to be the same as mine
Does anyone know a good supplier as backup in case the Fleabay ones are not suitable
Ps. Mine snapped in half & by the looks of things is as old as the car (2006) fortunately I was 300 yards from home !!
Thanks in advance
Kevin
Share this post
Link to post
I may have one on a spare pedal box thats in bits if you want me to check?
Share this post
Link to post
That would be smashing,thanks
Share this post
Link to post
Have added pictures - ok & broken, has fractured in the middle, would have thought the hooks would have snapped first?
Total length of spring (hook to hook) is 80mm
I guess a spring of the same length, but without the correct number of coils would not be suitable (strength wise)
Share this post
Link to post
Have you tried your local Ford parts department? I believe the part number you want is 1591622
Share this post
Link to post
All this spring is doing is taking any slack out of the cable and stops the clutch release bearing clattering (As it holds it against the clutch). As soon as you put your foot on the clutch pedal it engages a toothed part on the quadrant which then locks everything in place, the spring at this point is redundant. If the cable stretches over time the spring continues to take up the slack. A lesser weight spring should still work as long as it has enough pulling power to keep tension on the cable.
hth
Share this post
Link to post
Spot on, walked into the parts dept & was advised the part was too old, as newer cars don't use this method
Anyway we agreed it probably was from a Sierra & after a butchers at his system located the part but none in stock...... however neighbouring Salisbury had 19!
Went back almost on closing expecting to see a spring that wasn't the correct part,but was pleasantly surprised that it was Bob on....result, purchased 2 for good measure
Happy days & thanks to contributors on this thread
Edited by Friartuck
Share this post
Link to post
Great! I find it's always worth trying Ford!
Share this post
Link to post
"however neighbouring Salisbury had 19!"
I read that too quickly and thought thought for a moment you wrote 'Sainsburys' and wondered when they had started to stock old ford parts :crazy:
glad you got it sorted
Share this post
Link to post
Not had a chance lately to tinker with car,but did have a look yesterday & I have discovered that the cable has come adrift on the clutch
Without jacking the car up,first impression is that the sump cover will need to come of to access?
The cable both ends look good, as in every thing present & no signs of damage, so not looking to replace it
Advice please
Share this post
Link to post
there is a black 'boot' over the gearbox end of the clutch cable. It springs into the recess so should just pull out with a bit of a wiggle and a squeeze (of the boot that is).
You should be able to reach it under the car, i did mine the other day. The cable just hooks through a keyhole.
If you jack the car up make sure you have safety blocks so it can't drop on you as you have to reach under a fair distance.
hth
Share this post
Link to post
hth
Thanks,are you saying I won't need to remove sump cover? Does your car have one fitted,just trying to establish what I need to do down under!!
Share this post
Link to post
oh sorry i didn't quite get what you were asking.
Sump covers aren't a standard feature so will be however the original builder made it.
I would guess it won't need to be removed as the cable joins at the bellhousing so it further back than the sump.
this is a pic i found on google to show how the cable attaches. The boot is not on this pic but just fits over all of that.
http://media.turbosport.co.uk/2004/5/200459194937488090.JPG
Share this post
Link to post
