Sender unit
Jon
I have a fuel sender on the table in front of me. The Ohms between the pins (numbered as above) and the earth post are as follows:-
Pin1 float at top (full) = 21
Pin1 float at bottom (empty) = 176
Pin2 top = 200
Pin2 bottom = 67
Pin3 top = 183
Pin 3 bottom = 183
These "top" and "bottom" positions are with the float moved by hand and obviously out of the tank, and without the plug from the loom connected. Also the sender is an old one from the 1986 donor so the rheostat will have worn somewhat, never the less the values match niduncan's, more or less.
Test Footer
