Hello again,
I want to turn to you who know about these things for advice. I have acquired a Sierra based S7 with rear diff and Sierra steering but that’s it. I want to get an engine in to work around but I’m really stumped as to what to put in it. It will be both a track and a road car and obviously not my daily driver so I don’t mind if it is not the most comfortable to drive but I’d like it to be quick.
At first I was going to go down the bike engine route, I like the revs and gearbox. Then I had an offer of a V6 Essex but that fell through, now I’m considering a Zetec Blacktop.
The weight of the engine affecting steering is a concern. I think the S7 is light on the front end so do I in fact want a heavy engine…. Or not?
 I’m thinking that the Zetec should fit relatively easily on a t9 gearbox and can be tuned up.
I really am stuck on this choice so was after some input if you have time. Lowish budget also needs to be considered, or a higher budget over time.
If it’s a later engine and the car is to be IVA’d, does it not need the cat and sensors to pass though ? So although bike carbs are better, they won’t get through an IVA?
IVA comes before registration, and the car will be emissions tested for IVA based on the documented age of the engine. Bike carbs might be a problem and you’ll need a CAT.
However, if as Richie says you go for a non age related Q plate subsequent MOTs are visible smoke test only as per a pre 1974(?) registered vehicle so you have more freedom to tune the engine and remove cat etc.
