New member after Sierra stalks help
Flusted
Have been asked to wire a kit car from scratch using Sierra stalks, i thought i had most of it worked out, but now I've hit a few hurdles and require some help if possible please?
I've recently stumbled upon this site and found some useful diagrams, I've done most of it from scratch using a multi meter but i now have 2 problems.
1. If i have hazard lights working with ignition off, the indicators also work with ignition off, if i swap the supplies around i have, then the hazards don't work with ignition off but do with ignition on? I'm using a pre wired kit car fuse/ relay board.
2. Wipers. I'm struggling to understand the diagrams referring to whether you feed the stalk switch with power, and that outputs to the motor, the motor has the 6 pin plug, but 3 wires come from the motor to a white plastic plug.
Any help much appreciated, guidance to what i can meter etc
Test Footer
