Parts To Repair S7
Guest ANDY GARTON
I have bought a S7 (I think) that is damaged and need some parts.The car is monocoque construction with double wishbone front and live axle rear.
The parts I need are Nosecone,cycle wings which i,m thinking I will have to get from Robin Hood?. Also one of the rear coil springs is missing, can anyone tell me what car this is off?. I also need a streering rack and one of the lower front wishbones is damaged needing replacing. I would be grateful of any help and advice you could give. I will try and upload some pics.
Andy it could be either cortina or triumph based, look at the NW hoodies web site for identification. The nose cone should be available from Robin hood or lolocost, same company. It most likely would have had swept wings but either are available from them too. Rear springs unless much modified will be from donor car. Put your location in your details and I expect someone will come to drink tea and offer advice.
Peter.
... or if you're after a full 5 piece set of GRP (1x Nosecone, 2x Rear wheel arches & 2 cylce wings) in red, mail me. (I'll probably be prepared to split them) :rolleyes:
Adverts must go in the ADVERTS section which is a members only benefit. This topic will be locked but not removed, people may PM you if they want.
