1,032 -
Posts posted by biksz
Just disconnect the water pipes and join them up if you don't use car in winter or put manual chok on it
Not got sky hook but some skyline for the hook
Start what lol its the doo dah near the giggling pin am sure it's situated near the seat or was it in the boot lol
Jaime don't forget there is a couple of carbs already stripped in a box in your garage what brought down to go through for yours
Is it injection or carb
The giggling pin was situated near the seat wasn't it
Looks like an eddis
what is it as when i open page it shows circular stickers lol
did you check dizzy cap and rotor arm and leads incase they shorting out?
I spoke to emerald they do k6 with wiring loom of cheap but they runs the bob fine
Take allfun out it though lol mick where will I find them
Yeah its huge but will look ace under bonnet with a big cut out and bulge on or was thinking of doing what someone else did on here and cut a u shape in bonnet and lift it up with some brackets then mesh it.
Be tight but anything will fit lol.but gonna run a emerald k6 ecu and goto redo wiring loom on engine as all coating has cracked on wires so won't be any time soon when it gets fitted.might take a year to get all bits needed then good to go as then can check engine over properly
Same happened to my tank just put nut and bolts through with a washer with studs on and sealed round it the refitted sender job a good one
David I was watching that closely you did a very good job there and it sounds very nice.I not bothered about 5 speed box as don't use car for much apart from run to work and pottering around realy
Sounds good to me
Yeah it will just check teeth on inpu shaft they do a 18 and 19 tooth one
Come d mine lol
Yeah Dan looked into longer input shaft
Weber Choke Housing
in Wanted
If you want to kee . Auto choke though jaimo has deffo got that part atleast 2of them I think
