1,032 -
Posts posted by biksz
will put pic on later tnite when get in garage to get one and its the 2b yes
ebay itwm no 221139735946 its a supercharged pinto very unsure how it would look in a rh lol
hi any one no what shocks to put on back of rh super 7 as not sure if ride height should same as front.it is 7" from floor at front and nearly 9" at back. thanks
who gave matt there timing cover as i need one but not sure if to fit one as will be painting the pulleys has any one made half a cover to cover the belt and not the pulleys
does the mondeo st v6 fit the four speed box
hi bob i was same did not no which way to go but when had chance of registered kit car i thought its winter i can strip and rebuild what needs doing over winter which is what i am doing its my first one put your location if you near by you can always nip round see how far i got
also check pot 2 for scoring and possible ring on pot 2 but before stripping down i would of done compression test on all four to make sure compression was all same.
does the smoke smell?if so what of as this will give an indication of what could be burning.
hopefully once i fit a new one it wont need one for a while but gonna look at other options mower man pm you
i thought it was a bit close to gearbox rubber but if you have managed it i will have a look and see what space i got cheers
is it me or is there an easy way to renew the speedo cable on the s7 as with already having engine out i have took the box out to get the speedo cable of as with the box in situ i could not get to the cable circlip.
is he a member on here?
any got any pics of one tried finding one on a s7 but no joy.
hi does any one no if any one has fitted a full cage as i am opting out of having a screen i was thinking of fitting a full cage but not sure how to fit a full cage as hardly any space on the s7.
use some heat shrink over the metal lamp input then use seperate earth for bulb if that works you no it down to metal bublb holder interfering with it
agree engine out then you no its done properly for sake of a couple of hour taking engine out.worth the while.
funny you should mention that i was thinking same for mine but not had time to look into it lol
its a thing with black and white pictures i think.but no sound lol
managed to free off brake caliper but its the master cylinder that is causing the problem now i stripped it down all seals look ok but they are not letting brake fluid past so no brakes oops but not sure what problem is with master cylinder.seals?scoring,or other so gonna find another with same part number.
its a long shot but when did you have carbs balanced last or check the diaphrams in the carbs as i had a split diaphram on a bike and it lost power at high end of revs.
forgot to put the rh was built in 1994 but donor is 1983 but got an issue now with the master cylinder letting air in cause front drivers caliper is seized so need to get new caliper or try recon one i got then repair kit for master cylinder.all it is doing is hissing when you press brake pedal and there is no brake probably my own fault for trying to push caliper piston back in oops at least its an eay sort.(if any one got a spare one? not needed in back of their garage lol)
hi i am 5 foot 9 how easy it to sort a adjustable rack,i have the standard sierra rack on i will be only one driving it so dont want to change too much,i will look at the bias pedal box just need ideas as the rh i have got was built in 1994 so there is n ot much adjustment.
Supercharged Pinto
in Engine
it says he got it from a development place thats why it never took off i think lol its way too huge on the supercharger i bet by todays smaller more powerfull units you can probably get.
