277 -
12
Posts posted by Pintogogo
There is also a S7 on eBay now that has been the rounds and says it is registered as a Triumph Dolomite - Another Illegal Non IVA/SVA tested car methinks
Bit of a longshot but... can anyone recommend a company that manufactures or supplies Stainless steel 4 into 2/1 manifolds for a 2.0 Pinto in a Robin Hood S7 in the North / North East.
Thanks in advance
Harry
Hi Steve
I'll be there all being well, looks like a tin top job though eh lol, see you all on weds
Harry
Hi Guys
I'll be there all being well n I'll bring the kit if its not raining, (otherwise its tin top time lol)
See you all weds.
Harry
Thanks Guys
If you go for mini wiper motor try to get 2 speed unit as it has a self park unit fitted to it
Just fitted an accuspark electronic dizzy, coil, 8mm silicon leads n Iridium plugs and car started straight up, but ticking over about 1200 revs, timing marks (8deg BTDC on pulley I think??) looked way out with strobe but when brought into alignment engine seemed to slow down n not run as smooth, on road test it seemed to be pinking quite badly. Can anybody recommend ignition settings (possibly with diagram of cast pulley marks) for a 2L (205 block) engine to help me out
Thanks in advance ( no pun intended lol)
Harry
Thanks for advice guys, I purchased new accuspark, coil, leads n plugs, I'll set timing then hope for best
Harry
Thanks for the help guys, it is much appreciated, I've been looking at accuspark kits on ebay (dizzy, coil, leads n plugs) and was wondering will one kit fit all as I think my dizzy is a Motorcraft one ( black dizzy cap, spring contact on top of black rotor arm), or are there kits to replace Bosch and Motorcraft separately?
Engine idles steadily and it is a 'popping' in the exhaust (like a backfire), when the revs are dropped and then the accelerator pressed the engine pops for a second before picking up, I'm at work but i'll check vacuum connections and dizzy when i get home.
Thanks for your help it is much appreciated
Hi,
I have a front wheel pickup, and it only works when sensing attached magnets on the front hub as they whiz by (on the wheel studs in my case).
the sensor has to be very close to the magnets - like 2mm away.
I wonder if in disassembly you've knocked the magnets off.
If you want a 4 nice magnets (i got a box of 20), hit me with your address and i'll post them over to you
Thanks Fossett PM sent
never had dizzy cap off, thanks will look at that, if it has points/condenser will a electronic dizzy replacement make much difference
The sensor was removed to refurbish the wishbone but it looks to be back in same place (ring from lock washer)
My 2.0 pinto tends to misfire when revs drop when changing gear, car picks up and accelerates well but misfire annoying, replaced plugs leads etc, has anyone had similar
Cheers - harry
After removing front wheel to have puncture repaired my digital speedo has stopped working, I'm not sure if there should be some sort of pick up on inside rim of alloy to allow sensor on wishbone to transmit info to dash, all other functions (fuel, trip, water temp etc OK) can any one shed a little light on this - cheers harry
Hi
I saw a Robin hood with Black soft rubber trim around front mud guards which was about 15mm wide & looked really neat, all I can find at GBS/CBS n Flea bay is 10mm wide trim, does anyone know suppliers of a good rubber 15mm trim?
Regards
Harry
Hi Steve
I would be up for it deffo mate
Harry
I'll be there, see you all soon. Harry
Thanks for suggestions chaps, a westfield owner from Darlington loaned me his superb trailer free gratis, project now safe n sound back home
Please, Please, Please and I know its a bit of a longshot, but is any member able to hire/Lend me a car transporter/trailer in the Sunderland/Durham area to pick up my next project on Monday 22nd or Tuesday 23rd June Please
Kind Regards
Harry
Hi Steve,
Can i buy one from you please, if you PM me your address I'll send cash or would you prefer PAYPAL.
Regards
Harry
Hi guys I'll be there as well, look forward to the crack. Harry
Has anyone got a spare type 9 gearbox lever they want to sell please
Hi Guys,
I'll be there, look forward to the crack
Harry
Pinto 4 Into 1 Or 4 Into 2 Manifold
in Wanted
Thanks guys, Tractor its a through the side system I'm after, but cheers anyway
